Pointclouds from postgis / PostgreSQL
  • Feb 13, 2015 2:49 PM UTC
  • 185 views
Hi All,
Does anyone have any experience getting a pointcloud out of PostGIS?
We're using the PostgreSQL extension "Pointcloud" - https://github.com/pgpointcloud/pointcloud
Currently the data is stored in pcpatch data types and we extract it with pc_explode(column)::geometry. This returns to FME all of the individual points which if desired we can then recombine into a pointcloud.
But is there a way to get a pointcloud out *as* a pointcloud? I've tried PC_AsText, but the JSON it returns isn't GeoJSON so I can't just feed it straight into a GeometryReplacer. And there's no PC_AsBinary for the pcpatch datatype.
Anyone have any thoughts or experiences with this?
Thanks,
Jonathan
ronan
  • May 20, 2022 10:16 AM UTC
Hello Johnatan,
the anwer is a bit late ^^, but maybe it will be useful for another user.
To read pgpointclouds in FME as a pointclouds, you can transform it to a multipoint format in SQL :
  • Use a SQL EXECUTOR with the option : Combine attributes = result attribute only
  • Then you can use a SQL like this one :
SELECT exp.geom
 FROM  public.sondes,
 lateral
 select st_Collect(points::geometry) AS geom
 FROM public.pc_explode((patch)) points
 GROUP BY PC_Get(points, 'id')  ) exp
 LIMIT 5000
Then the result will be a multipoint,much faster to use (even the SQL request is much faster).
One difference is that multipoint gather 4 dimsensions (x, y, z, M), and pgpointclouds as much as needed. Here is another version of the sql to collect the FK information gathered for each point in pgpointclouds format (the additional attribute has to be declared in the GROUP BY)
SELECT  id, exp.geom
 FROM  public.sondes,
 lateral
 select
 PC_Get(points,'id') id,
 LIMIT 50
Ronan
