Pipe invert - Civil 3D Reader
  • Jun 9, 2015 7:48 PM UTC
  • 60 views
I would like to know if it's possible to read pipes invert elevation from a Civil 3D file using Civil 3D reader. It seams that I can't see this information in FME Data inspector but I hope there's a way to get that attribute out of Civil 3D files. Same thing for Structure insertion rim elevation.
I'm using Edition: FME Desktop Oracle Edition (floating) 2015.1 with Win64
Thanks for helpin' !
pratap
Forum|alt.badge.img+12
  • Jun 10, 2015 6:58 AM UTC
I understand that you want to know pipe elevation in DWG 3D file. Try to check by activating format attributes if an attribute is present else other trick is to calculate the elevation since we know the Z-Value by subtracting pipe dia.
Hope this trick help.
