pass a list of microstation files to a reader
  • Jun 3, 2014 4:27 PM UTC
  • 68 views
Article 000002244 seems to provide the solution I am looking for (using python script to specify feature types), but I'm unclear about setting the path for each microstation file that I am loading. I can create a list of the files I want to load to the reader, but there are multiple paths. I am creating the list by iterating through a directory and subdirectories and searching for files with microstation file extension. I'm not sure where to include the path information for each file?
  • Jun 3, 2014 9:09 PM UTC
If you are just searching specific directorys and sub-directories for DGN, why not used the "advanced browser".
 If you are being particular about the dgn you are loading, then you could pass in the path and filename through a python parameter (like the article) and return a concatenated list of the files to be read (formatted appropriately!). You could then set the "source dataset" parameter to take its value from the python parameter.
Cheers,
Todd
  • Jun 3, 2014 9:24 PM UTC
Or another option is to read your text file (with each path and filename) on a new line into a featurereader (set it up to read one file at first), and then, in the navigatior window, open transformer tree and then the featurereader tree and change dataset to @Value(text_line_data)
  • Jun 4, 2014 3:13 PM UTC
thanks for the replies! I am not too advanced of an FME user yet.. I have many many subdirectories so I tihnk using the advanced browser might be tedious. I will try to see if I can work out the second option you posted..
  • Jun 9, 2014 5:38 PM UTC
I am trying to second option but don't totally understand - in the feature reader, do I load my text file with paths as the dataset? The feature reader wants to know the type of file, and I have a series of microstation v7 and v8 drawings. I don't follow the @value(text_line_data). Sorry but still new to FME!
