Parquet File not Readable over s3 because of slashes
  • Nov 27, 2024 9:45 PM UTC
  • 237 views
mccunee
Forum|alt.badge.img+3
I have many parquet files stored in an s3 bucket; when I use the s3 connector to download the parquet file, I am able to read it successfully, but passing the s3 uri (“s3://”) raises an error:
PARQUET reader: PARQUET reader: Failed to open file 's3:\my-bucket-s3-test\fme-test\test.parquet' for reading.  Please ensure that the file exists and you have sufficient privileges to read it
Failed to obtain any schemas from reader 'PARQUET' from 1 datasets. This may be due to invalid datasets or format accessibility issues due to licensing, dependencies, or module loading. See logfile for more information
When I try to pass the url:
PARQUET reader: PARQUET reader: Failed to open file 'HTTPS:\s3.us-west-2.amazonaws.com\my-bucket-s3-test\fme-test\test.parquet' for reading.  Please ensure that the file exists and you have sufficient privileges to read it
When I use the feature reader, regardless of whether or not I specify a web connection, it converts forward slashes to back slashes. How do I work with this?
Context:
There will be 1000s of files in this bucket. I am using “list” to generate a feature of the pathnames, then using automations to process the files in this bucket. I do not want to download all of these files, given the memory strain, and I need to use attributes to pass the uris to next part of the process
hkingsbury
Forum|alt.badge.img+73
  • Nov 28, 2024 6:40 PM UTC
My understanding of how s3 works in FME is that you do need to download each file before being able to use it in a reader.
The approach i’d take in this scenario is:
  • Get a list of all the files in the bucket
  • Explode them to individual features
  • In a custom transformer (set to group by the file name)
    • Download the file
    • read it
    • delete the downloaded file
    • perform any required analysis/processing
mccunee
  • Dec 3, 2024 7:26 PM UTC
Ok, thank you ​@hkingsbury much appreciated for the clarification. I did figure out something, but it still downloads the Parquet file to temp (which slightly undermines the purpose of cloud optimized formats). In the Apache Parquet format the drop down arrow has a browse web - select from s3 option. This reformats the URL in a way that safe can read, which isn’t your typical s3 url. I can then modify with a text editor to use different inputs. This is kind of clunky however, and the feature reader UI makes it really tough to modify s3 URIs. If any developers read this- improvements to the s3 browsing and parsing would be much appreciated.
hkingsbury
  • Dec 4, 2024 2:53 AM UTC
It would be worth creating an idea with this - https://community.safe.com/ideas
bruceharold
Forum|alt.badge.img+20
  • Oct 6, 2025 4:59 PM UTC
What I have done is create a DuckDB database connection to a .duckdb that contains a view definition of your S3 files, using a glob path for the files you want.
Then in a workspace use a SQLExecutor to read the data:
FME_SQL_DELIMITER ;
install spatial;
load spatial;
select * from "MyDivisionView";
Loading the spatial extension may not be required for your data.
