Overwrite option in Google Drive Connector “in download option”
Hi all,
I’m using Google Drive Connector to download a folder contains images to process them later and convert them to points feature class. When I rerun my workbench I got an error from google drive connector said that the destination exists and when I delete this folder my workbench works fine.
Is there anyway that I could setup my Google Drive connector to overwrite the existing folder or anyway to delete that folder through the workbench it self before the google drive start download it again?
Thanks,
Rawan
sigtill
Forum|alt.badge.img+24
  • October 15, 2019
Hi @rawansaleh - I have updated this question to be able to use the FileCopy-writer to delete a file on windows: https://knowledge.safe.com/questions/2948/file-copy-delete.html?&childToView=100347#answer-100347
  • November 12, 2019
I'm not sure why this method is not working for me, but I found another way to do this which will delete the existing folder
you can use "System Caller" transformer and put the following in Command Line @RD /s/ Q "Your Folder Path"
sigtill
  • November 13, 2019
Strange, which version of FME do you have @rawansaleh ?
  • November 13, 2019
@sigtill I'm using 2019
