overwrite existing attribute
  • Jul 22, 2020 2:43 PM UTC
  • 110 views
I have a .dxf with points and lines within different layers and blocks. For one layer of data, I need to delete the attribute value within the block and insert in it the geometric value z. Which transformer is best to use?
daveatsafe
Forum|alt.badge.img+24
  • Jul 22, 2020 6:33 PM UTC
Hi @lola,
You can use the ElevationExtractor transformer to do this. Please set the Elevation Attribute parameter in the transformer to the attribute you want to insert the Z into. This will overwrite the previous value.
  • Jul 23, 2020 7:30 AM UTC
Hi @lola,
Thank you for answering. i used it but it doesnt solve the problem.perhaps because it is value inside the block.
  • Jul 23, 2020 7:56 AM UTC
i tried it on another set of data and know it works :)
