Override Coded Domain Values
  • Nov 5, 2018 4:00 PM UTC
  • 66 views
Good morning,
I am having trouble overriding a coded domain value within a GDB. I received a GDB and I do not need the coded domain values assigned to one of the attribute values. Instead of going through each feature class and remove the coded domain option, how can I override the current coded domain values in FME?
I am using the GDB API writer with Feature Operation: Insert and Table Handling: Truncate Existing.
Appreciate any assistance!
David
I guess having ESRI GDB API as writer cannot override any coded domain values. However the regular ESRI GDB writer can override coded domain values.
