OSMDownloader limit
  • May 3, 2018 2:36 PM UTC
  • 95 views
Hi
I started to use big volume of OSM data in my work, with requirements of extension that no any available OSM online server page can offer me. For that reason I used OSMDownloader to obtain the data.
However I observed a limit of the data volume available to be downloaded. With easy editing of the custom transformer I can skip the limitation of extend, but I still find a limit of the resulting .osm file in 1.048 Mb. I mean that probably there is a limit in the HTTPCaller transformer, or in a time limitation, or maybe in the xml format?
Please, some of you could guide me about this limitation?
Best
Julián
jdh
Forum|alt.badge.img+41
  • May 3, 2018 4:34 PM UTC
I believe that the Overpass API has query-limits.
If you need large amounts of data, consider the regional extracts from Geofabrik http://download.geofabrik.de/
