OSM file to ArcGIS File GeoDB
  • Jan 17, 2013 5:00 PM UTC
  • 79 views
 Hi All,
I have some problems when I try to convert OSM file to ArcGIS FileGeoDB. These problems are mainly due to invalid or duplicate field name in the OSM file.
When I convert the same OSM file to Shape File everything is fine.
So my question is when Shape File export can find and remove that kind of errors why  FileGeoDB (API /Arc Object) export cannot find and fix that kind of errors in the field name?
Can someone explain me a way to automatically find/fix these problems, rather than run the workbench until it fails and then fix them manually?
Is there something available in FME like ValidateFieldName in ArcGIS?
I am using FME 2012 64bit on Windowx 7 64bit.
davideagle
Forum|alt.badge.img+21
  • Jan 17, 2013 5:51 PM UTC
Hi - the trouble you are hitting is that different formats have different 'rules'. Particularly around column names formats are very pedantic. For example MapInfo Tab doesn't like column names to start with a number, Shape won't accept column names longer than 10 characters and sometimes specifies UPPERCASE column names only. As a result different formats react differently to different column name structures.
With databases things get even more hairy as you might have to also avoid reserved words too!
http://forums.esri.com/thread.asp?c=93&f=985&t=286050
You'll need to try to trap the issues in your workspace... Transformers like the AttributeRenamer offer basic support and will allow you to create more acceptable attribute names for your intended target or perhaps names that are acceptable to multiple targets... but you may want to look at the SchemaMapper as a way to store your old names and their desired mappings outside of your workspace (useful for more complicated renaming).
Hope that helps...
P.s. Always avoid spaces, they cause lots of trouble!
  • Jan 18, 2013 8:37 AM UTC
Thanks for SchemaMapper tip, I think that is what i am looking for.
davideagle
  • Jan 18, 2013 9:31 AM UTC
No problem. There's a little in here about the SchemaMapper about 35mins in
http://www.youtube.com/watch?v=FObhAEwo6OM
But this might be more practical help:
http://evangelism.safe.com/fmeevangelist71/
Essentially:
The Feature Type Map = Move features from one layer to another
The Attribute Map = Is likely what you need as this is a more flexible AttributeRenamer
The Add Attribute Map = Is as you'd expect an AttributeCreator
