Orientation of PDF Output
  • Jun 6, 2018 2:08 PM UTC
  • 175 views
Good day,
I create one map per ship showing its track of the last month. The map is output as pdf (Adobe Geospatial PDF Writer). By default the page orientation is portrait. I would like to dynamically change the orientation to landscape depending of the map's bounding box (width/length). How can I do it?
Best answer by debbiatsafe
Hi @kat
You can use a Tester or TestFilter to route features based on the bounding box ratio (eg. if width greater than length = portrait, etc.) to an appropriately configured PDFPageFormatter. You will be able to determine the page size and orientation using the PDFPageFormatter.
debbiatsafe
Forum|alt.badge.img+24
  • Jun 6, 2018 9:45 PM UTC
Hi @kat
  • Jun 7, 2018 1:15 PM UTC
Hi @kat
Thanks. Working fine. I even don't need the PDFPageFormatter. I only create the pdf_page_size attribute.
deanhowell
  • Jul 15, 2019 2:07 AM UTC
Hello @kat, I am trying to do the same thing, so was wondering if you could do a screen shot of what you did to solve this issue please?
