Oracle type 3007 detection
  • Sep 16, 2014 1:10 AM UTC
  • 104 views
I have an oracle table which is supposed to be type 3003 but has a type 3007 in it somewhere.  How can I test for type 3007, multi-polygon?
I'm running 2012 SP 2 build 12238 64 and 2013 SP4 build 13547.
Cheers,
  • Sep 16, 2014 11:36 PM UTC
David,
I have tried that with no luck.  All my features are oracle_area.  Here is the error log from my original workbench:
2014-09-17 09:01:11|   2.5|  0.0|ERROR |Execution of statement `UPDATE TOPO_OWNER.VEGETATION_2500 SET SUB_CLASS = :SUB_CLASS, SCALE = :SCALE, RELIABILITY_DATE = :RELIABILITY_DATE, ACCURACY_HORIZONTAL = :ACCURACY_HORIZONTAL, ACCURACY_VERTICAL = :ACCURACY_VERTICAL, STATUS = :STATUS, SOURCE = :SOURCE, GEOMETRY = :GEOMETRY WHERE UFI = :UFI' did not succeed; error was `ORA-29875: failed in the execution of the ODCIINDEXINSERT routine
ORA-13375: the layer is of type [3003] while geometry inserted has type [3007]
ORA-06512: at "TOPO_OWNER.OVM_UPDATE_1013", line 3
ORA-04088: error during execution of trigger 'TOPO_OWNER.OVM_UPDATE_1013''. (serverType=`ORACLE8I', serverName=`dcdbprod', userName=`PW_RWK', password=`***', dbname=`')
2014-09-17 09:01:11|   2.5|  0.0|INFORM|FME Session Duration: 5.6 seconds. (CPU: 2.2s user, 0.2s system)
2014-09-17 09:01:11|   2.5|  0.0|INFORM|END - ProcessID: 1652, peak process memory usage: 189040 kB, current process memory usage: 110588 kB
Program Terminating
Translation FAILED.
Don't know where to go from here.
Thanks,
Russell
  • Sep 17, 2014 9:44 AM UTC
if your geometries are of type SDO_GEOMETRY (Oracle spatial), you could try something like
SELECT * FROM my_polygons a WHERE a.geometry.sdo_gtype = 3007;
You can either put this into a SQLCreator or execute it from e.g. SQLDeveloper, TOAD, etc.
David
  • Sep 18, 2014 2:32 AM UTC
David,
Thanks for that tip.  It didnt solve the problem directly but put me on to another approach.
Cheers,
  • Jun 5, 2019 8:54 PM UTC
The query is:
SELECT
    A.<GEOMETRY_COLUMN>.GET_DIMS()
    || A.<GEOMETRY_COLUMN>.GETLRS_DIM()
    || '0'
    || A.<GEOMETRY_COLUMN>.GET_GTYPE() AS SDO_GTYPE
FROM
    <SPATIAL_TABLE> A;
The methods will not work unless you use an alias.
