Oracle to shapefile - Unable to output data to file
  • Aug 6, 2018 7:50 PM UTC
  • 5 replies
  • 101 views
I am attempting to convert from Oracle to a shapefile and getting the following error consistently.
look like it is failing on the .dbf file. Any suggestions?
Best answer by svwellman
It turned out that I had an attribute column type set to number when it should have been set to char.
  • Aug 6, 2018 11:00 PM UTC
Weren't there any message describing what happened, other than the last few lines shown in your screenshot?
  • Aug 7, 2018 6:32 AM UTC
Does is work if you write the shape file to any other disk?
Check for available disk space on E:
If E: is a non-local disk, check for sufficient rights.
  • Aug 7, 2018 12:23 PM UTC
No I found nothing else in the log. I am going to try devid_r's suggestion and try writing it to another disk.
  • Aug 7, 2018 1:41 PM UTC
Forum|alt.badge.img+54
  • Feb 20, 2020 4:32 PM UTC
There really should be a better error message for this
