Oracle spatial Index
raphael
Participant
Hello,
How can i choose my tablespace when i create my spatial index with FME 2013 ?
Thank you
Raphael
  • July 11, 2013
under the Writer feature type, go to properties and "Format parameters". You can specify the "Spatial index name" there, try doing it on the form MYSCHEMA.MYINDEXNAME, where MYSCHEMA has the desired index tablespace as default tablespace.
I haven't tested it, but it might / should work...
David
raphael
Participant
  • Participant
  • July 11, 2013
Hello David,
Thank you
I've tested your solution but the translation failed
Execution of statement `CREATE INDEX ME_EDS_IDX.TEST_INDEX ON TEST_INDEX2(GEOM) INDEXTYPE IS MDSYS.SPATIAL_INDEX' did not succeed; error was `ORA-28100: schéma de fonction de règle ME_EDS_IDX non valide'.
  • July 11, 2013
Bonjour Raph,
are you certain that ME_EDS_IDX is the name of a schema and not a tablespace?
David
raphael
Participant
  • Participant
  • July 11, 2013
I'm sur, ME_EDS_IDX is a tablespace
Raphael
  • July 11, 2013
Well, there is your error :-)
You need to specify a SCHEMA.
David
raphael
Participant
  • Participant
  • July 11, 2013
David,
if I use this sql command my index is ok
CREATE INDEX TEST_INDEX ON TEST_INDEX2(GEOM) INDEXTYPE IS MDSYS.SPATIAL_INDEX PARAMETERS ('tablespace=bdp_idx');
Raphael
  • July 11, 2013
Raphael,
If that works, you could also just disable the spatial index on the Writer, then create it manually with your command using an SQLExecutor.
David
raphael
Participant
  • Participant
  • July 11, 2013
Thank you David,
I think I will keep the sqlexecutor
Raphael
