Oracle Non Spatial Reader to CSV Writer
I'm relatively new to FME, so any help here would be greatly appreciated.
I can link to a SQL server to pull specific information from a table. However, I don't have write-access to the server, so I want to save the results of my SQL query in a CSV file. I've tried just doing a Reader of Oracle Non Spatial to a Writer of CSV. It reads the data fine, but nothing actually gets copied into the CSV File; it is just an empty file.
I'm obviously missing something here. Can anyone help? Much obliged!
fmelizard
Forum|alt.badge.img+19
  • July 9, 2013
Are the attributes of your reader schema present on the csv writer?
You can quickly copy the input attributes by right click on the writer> copy atribute from feature ....(select your input feature type)
fmelizard
  • July 9, 2013
Optionally you can set the translation to dynamic and not worry about attributes any more....
  • July 9, 2013
Ah, brilliant! That was the piece I've been missing. Thanks so much!
