OBJ reader does not read MTL
  • Mar 10, 2023 2:07 AM UTC
  • 55 views
Hello,
When use Obj Reader,materials aren't appearing properly. .mtl does not refer to additional image resources. Attachment is my obj file.
Thanks
kailinatsafe
Forum|alt.badge.img+24
Hello @huangran​, thanks for posting! Are you able to specify which file contained in the zip folder you're having issues with? There are quite a lot of different files/formats in here.
Is your data read into FME successfully, but just not textured? Do you recieve any errors on read? What version of FME are you using? Happy to help, Kailin
