Not able to write to AGOL
nea
Forum|alt.badge.img+9
When I write to AGOL I get the following error message:
|ERROR |Attribute(64 bit real)             : `Company_Material_Unknown' has value `1312'
I’ve tried various data type for both the writer and the attribute manager before the writer.  Nothing works.  I have another AGOL writer in another place in the FMW (different data stream) and it works fine.
Best answer by nea
That worked!!!  Thanks so much!!
I’m interested why there is this problem because I’m writing this data as a non-spatial (no geometry) table.  I would have probably never thought of a coordinate system although it is right there in the log file.
This is the Coordinate System of the spatial data within the FMW:
By manually selecting a CS I found this one which I’m not real sure about.  Although, since this is a non-spatial perhaps it does not matter.
Would the CoordinateSystemExtractor give me the CS I could assign with the CoordinateSystemSetter?
Thanks again for your help.
hkingsbury
Forum|alt.badge.img+55
  • February 20, 2024
What is the type for that field in the destination dataset?
nea
  • February 20, 2024
For text fields I’ve have String(width).  For all other fields I’ve tried Integer, Double, and String(width).
nea
  • February 20, 2024
nea
  • February 20, 2024
Here is an AttributeManger that performs a pivot of the data.  It is upstream from the Writer.
hkingsbury
  • February 20, 2024
Are you able to upload your entire log? I suspect there are some other key entries in there that will help narrow down the cause
nea
  • February 20, 2024
I’m currently running a length FMW but will get this to you as soon as it is finished.
nea
  • February 20, 2024
124 Errors, 2 Warnings.
nielsgerrits
Forum|alt.badge.img+54
Looks like an error about a coordinate system missing. If you set that correctly using a CoordinateSystemSetter, does it work?
2024-02-20 14:31:50|  46.3|  0.0|ERROR |ArcGIS Online Feature Service Writer: Encountered a feature without a coordinate system. All features being written must have a coordinate system
2024-02-20 14:31:50|  46.3|  0.0|ERROR |Python Exception <FeatureMissingCoordinateSystem>: FMEException: 926858: ArcGIS Online Feature Service Writer: Encountered a feature without a coordinate system. All features being written must have a coordinate system
hkingsbury
  • February 20, 2024
2024-02-20 14:31:50|  46.3|  0.0|ERROR |ArcGIS Online Feature Service Writer: Encountered a feature without a coordinate system. All features being written must have a coordinate system 2024-02-20 14:31:50|  46.3|  0.0|ERROR |Python Exception <FeatureMissingCoordinateSystem>: FMEException: 926858: ArcGIS Online Feature Service Writer: Encountered a feature without a coordinate system. All features being written must have a coordinate system
Yes, I’d be inclined to think this is the primary issue
nea
  • February 20, 2024
