Not able to create a web connection
  • Sep 25, 2024 7:47 PM UTC
  • 9 replies
  • 158 views
nea
Forum|alt.badge.img+9
i”m unable to create the web connection despite all the documentation.
Best answer by todd_davis
You could try that token url in the “token url” parameter in the web connection you showed. Not sure it will work because I don’t know how that web service is setup, but worth a shot.
hkingsbury
Forum|alt.badge.img+73
  • Sep 25, 2024 8:28 PM UTC
Is there any more information in the log?
I’m also assuming that you’ve tried going that URL and using those credentials to login successfully?
nea
  • Sep 27, 2024 4:02 PM UTC
I’ve used this URL and credentials to successfully log into Portal in Arcgis Pro and in a browser.  The log file had no information.
todd_davis
Forum|alt.badge.img+23
  • Sep 27, 2024 10:13 PM UTC
I have not seen this “Esri ArcGIS Portal token” Web service before (Most people use Oauth2). Can you share a screenshot of the Web Service configuration.
My first suggestion is that the login URL is not the same as the token URL. The token url can be found by looking at https://Domain/portal/rest/info
Cheers,
Todd
nea
  • Sep 30, 2024 4:08 PM UTC
I placed “/rest/info”  after “...portal” in the connection URL but got the error message “Could not access...”
I chose to use a web connection because i have other web connections with AGOL (that work). I wanted to keep all my connections in one place.
todd_davis
  • Sep 30, 2024 6:19 PM UTC
Try https://URL/portal/sharing/rest/info then. This is to get the token generation location url for use in a token service webconnection.
The choice of a webconnection is the best. It just a query around what looks like a webconnection using token service rather than an Oauth2 connection. The standard ArcGIS Online connection in FME uses Oauth2 where you get to authorise in a pop-up window, but the current connection setting you have above in storing the username/password and therefore, looks like a token service. The Oauth2 connection is a bit harder to setup the first time but it is documented:
https://support.safe.com/hc/en-us/articles/25407772142733-How-to-Create-an-ArcGIS-Enterprise-Portal-Web-Connection-OAuth-2-0
nea
  • Sep 30, 2024 6:35 PM UTC
BTW, thanks for your help.
Got some successful returns:
Owning System URL and Token Service URL available. What do I do with the Token Service URL?
nea
  • Sep 30, 2024 6:43 PM UTC
IT WORKED!!!  Placed the URL into the Token URL and the connection was made.
Thanks for all your help.
you will get the credit.
Thanks again.
todd_davis
  • Sep 30, 2024 6:47 PM UTC
nielsgerrits
Forum|alt.badge.img+67
Can you share the configuration of the webservice for others to replicate?
