No commit or update with a postgresql writer
  • Aug 14, 2019 3:58 PM UTC
  • 70 views
Hi
I juste use an AttributeManager after a reader which works fine. My value is changed.
but the writer doesn't update my record in the table.
I tried all options in the writer to match the row selection ... nothing works.
Do you have an idea about this issue ?
Thanks
erik_jan
Forum|alt.badge.img+26
  • Aug 14, 2019 4:08 PM UTC
Can you add a screenshot of the Writer Feature type settings?
That could make the issue a bit clearer.
  • Aug 19, 2019 7:20 AM UTC
Sorry, I forgot to put my screenshot. (here's my writter feature type tab)
I juste want to update the "complement" column . I succeeded another sql order to insert value in a new table.
  • Aug 20, 2019 7:23 AM UTC
Well, after several tests, I guess my mistake was the name of the column with row selection. I put the name of the column I was modifying.
