NITF to PostGIS errors
  • Mar 15, 2018 4:27 PM UTC
  • 84 views
I am getting the following error,when trying to write all the NITF attributes to the PostGIS table.
Bulk copy failed on table 'public.EGPL' using delimiter ':'. Error was 'ERROR: value too long for type character varying(4)
CONTEXT: COPY EGPL, line 1, column nitf_fhdr: "NITF02.00"
... Last line repeated 2 times ...
FME Session Duration: 3.2 seconds. (CPU: 2.0s user, 0
Best answer by david_r
Looks like FME may have issues with the automatic writer schema definition for this format. Try manually expanding the data type for the "nitf_fhdr" attribute, e.g.
  • Mar 15, 2018 4:42 PM UTC
  • Mar 16, 2018 2:12 PM UTC
thanks very much
