New IFC writer to re-write ifcPresentationLayer
  • Apr 23, 2026 7:29 AM UTC
  • 7 replies
  • 322 views
kevins0625
I was hoping to use the new IFC writer available in FME 2026.1 to update the IfcPresentationLayer attribute values from IFC to IFC.
The idea was to disregard the current layers exported from Revit from others and define our own layer presentation for the models so we can turn certain layers on and off in our platform (Trimble Connect).
I used the reader to load the IFC file (in 2x3 format), and it successfully retrieved all layer attributes into FME. However, I don’t seem to be able to write the updated layers.
In fact, even without adding any transformers—just using the reader and writer from IFC to IFC—the layers are lost.
So I’m wondering if anyone has had success using the latest FME reader and writer for rewrite the layers
Thanks!
Best answer by crystalatsafe
Hi ​@kevins0625
Our team is currently making a few changes to IFCPresentationLayer support that are targeted to be fixed for 2026.2 (Internal reference: FMEENGINE-87705). I can let you know as soon as this is released!
kevins0625
  • Apr 23, 2026 1:24 PM UTC
I opened the two IFC files (original and exported) in Notepad. I can see that the exported file still includes the IfcRepresentationAssignment information, but it doesn’t include any element IDs, whereas the original file includes the elements IDs for each layer.
It might be possible that the IFC_API writer doesn’t write the list of elements IDs included in the original file.
crystalatsafe
Forum|alt.badge.img+32
  • Apr 28, 2026 6:46 PM UTC
Hi ​@kevins0625
kevins0625
  • Apr 30, 2026 6:07 AM UTC
Hi ​@kevins0625
Thank you! that would be a game changer for this writer.
It would also be awesome if we could create/delete layers and reorganise them based on attributes such as element IDs. It’s surprising that many users still rely on layers to control what they see on screens.
crystalatsafe
Hi ​@kevins0625
Yes! We will be able to create IfcPresentationLayers and allow for linking whatever elements you like to them via ID attributes.
To delete a layer, you can simply not send the PresentationLayerAssignment features in question to the writer and make sure not to link to them on individual features, and they won't be created in the output file.
crystalatsafe
Hi ​@kevins0625
I wanted to provide an update that this is now targeted for the 2026.3 release to allow sufficient time for thorough QA. Thank you for your patience! I will let you know as soon as it is released.
kevins0625
  • May 18, 2026 11:23 PM UTC
Hi ​@kevins0625
Thanks for the update, can’t wait to see this fixed!
crystalatsafe
Hi ​@kevins0625
FME version 2026.3 is now available. You can download the latest version at: https://fme.safe.com/downloads/
