NetCDF with rotated coordinates
  • September 26, 2019
  • 8 replies
  • 75 views
monicarm
I'm working on a project where I need wave models created in MatLab. I have download them but when reading I get rotated coordinates.
For some reason, wave models operate with rotated coordinate systems as opposed to conventional ocean models (rlat, rlon). How can I manage to read and rotate this data with FME?
Best answer by david_r
Is this concerning coordinate systems with rotated (offset) poles?
Unfortunately FME does not handle these very well out of the box, but there may be some workarounds.
monicarm
  • September 27, 2019
Yes, that's the problem. Here is a print screen:
monicarm
Yes, that's the problem. Here is a printscreen of the netcdf.
There are a couple of hints and tips over at this post that you may want to take a close look at:
https://knowledge.safe.com/questions/43959/netcdf-rotated-coordinate-system-rlat-rlon.html
It includes a small python library that I wrote to calculate back and forth between rotated poles and regular lon/lat. It's fairly easy to incorporate the functionality into FME (PythonCaller) if you know a little Python.
Hope it can help.
monicarm
  • September 30, 2019
Hope it can help.
Thanks @david_r. I had already read this question but I was just wondering if FME had already a new solution. I will take a look at it.
rob_m_esriuk
Forum|alt.badge.img+5
  • March 24, 2021
Hope it can help.
David, I would be interested to look at the python, however time moves on and the safe site seems determined not to show me that link, has it been moved?
  • March 24, 2021
It probably went missing in The Great Forum Migration a few months back. Here's the file in question: https://www.dropbox.com/s/mib2t17nrs92k1t/rotated_grid_transform.py?dl=0
rob_m_esriuk
  • March 24, 2021
thanks David
