Nested folders and fanout with KML
  • March 6, 2013
  • 81 views
philsc
Hi !
Is there a way I can get my fanout result nested in a subdirectory in a KML/KMZ file ?
Should be quite simple, but I just can't make it work.
I have a MapInfo table with schools which I would like to separate in type of schools and by region. Type of schools, language and regions are held in columns in the MI table.
Here is a sample of what I'm trying to achieve :
Schools (document name) - Elementary (1st order subdirectory) - English (2nd order subdir) - Region 1 (3nd order subdir - that's where my fanout should be) - Region 2 - ... - French (2nd order subdir)
- Region 1 (3nd order subdir - that's where my fanout should be) - Region 2 - ...  Secondary - English (2nd order subdir) - Region 1 (3nd order subdir - that's where my fanout should be) - Region 2 - ... - French (2nd order subdir) - Region 1 (3nd order subdir - that's where my fanout should be)
- Region 2
- ... University
Every time I use a fanout, my subdirectories are automatically placed at the root of the KML document.
Is this possible to force the fanout result to a subdirectory ?
Thanks for your help folks.
davideagle
Forum|alt.badge.img+21
  • March 6, 2013
Hi - you need to look into the kml_parent and kml_id attributes. Here's an example that shows you how:
http://fmepedia.safe.com/articles/FAQ/KML-Folders
