Missing Attributes after Feature writer
  • February 18, 2020
  • 5 replies
  • 172 views
gogopotter90
Forum|alt.badge.img+13
i have read lots of article about Feature Writer , but i could not get the point ,how can i get my attributes and connect it to excel writer without effect on my output ,it does not matter to show this attributes in excel file output but i want to keep it in excel writer to use it later
i have at the beginning excel file then i converted it to csv then i apply the output on excel file but i missed some attributes that i need to use
most of attribute are missing ,onle my result what i can get ,could i ask,how can i find the rest of Attributes
exactly my target ,i want to name excel writer as the field name included attribute but i could not find most of attributes after Featurewriter.
FME version 2018.1
Best answer by takashi
Do you perhaps want one of these options for Output Ports - One per Feature Type or Specified
  • February 18, 2020
gogopotter90
  • February 18, 2020
thanks for ur reply but this attribute i did not use it in stringconcenator so it does not show with me in feature writer ,i mean i created Feature type Name and it included another attributes .
i tried to add this attribute in Stringconcentrator and so on i am still not able to see it seperately and i choose one per feature type and also it gives me bad effect on the expected result
thanks for ur suggestion ,my output port was none so i changed it to one per feature type but iam still confused ,i want to have this attribute with me but not effect on the result.
gogopotter90
  • February 19, 2020
could i ask why i have fme_basename empty after Feature writer ,
this is the feature that i want to have after feature writer but i found is missing and i tried alot but no success
  • February 19, 2020
I wasn't able to reproduce the issue with either FME 2018.1.2.1 or FME 2019.2.3.
Are you sure that "fme_basename" definitely has a value before the FeatureWriter?
gogopotter90
  • February 19, 2020
yes ,it has a value . i checked it by inspector . FME version 2018.1
