Minecraft -adding to Existing Worlds
  • Jul 27, 2018 6:37 PM UTC
  • 140 views
Hello all
Hoping someone can help, i have a minecraft world created with FME, this world contains the Ground mesh.
i now have the 3d geometry for the trees and buildings,
i want to add this geometry into the exisiting minecraft world.
Any ideas.
Thank you
Best answer by mortonprice
Got it working, As @XiaomengAtSafe said, you cant modify a world, but you can create a new one, for Example (World 3 a New world) contains (World 1_Old) and (World 2_New content) and combines the two together. However it wouldn't work for me unless i put each world level folder on my desktop. Kept saying i didn't have permission otherwise.
xiaomengatsafe
Forum|alt.badge.img+11
Hi @mortonprice, It doesn't look like you can add to an existing Minecraft world, according to the documentation. You should be able to read back the world you already created, and write that to a new world, together with the new geometries representing trees and buildings.
  • Aug 1, 2018 9:17 AM UTC
jkr_wrk
Forum|alt.badge.img+37
  • Aug 1, 2018 10:24 AM UTC
Keep in mind that some data could get lost. Last time I tried chests got invisible and bed colour changed to red.This is because block entity data is not written.
Good Point i have only tried this basic blocks, Grass, and Wool dirt and sand.
ill keep this in mind
Thank you
