MicroStation V8 to MicroStation V7
I am having to convert MicroStation V8 to MicroStation V7 design files. In doing so I am required to select a seed file for the V7 design file output. Is there a way to use the global origin and units of resolution from the source V8 file? Is there a way to strip off the element linkages that are not valid in a V7 design file?
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
