microstation resource font file crashing workbench
  • Oct 17, 2016 5:10 AM UTC
  • 46 views
zubairsm
Forum|alt.badge.img+9
I am translating autocad dwg file to microstation dgn file, where I am also writing Tag attributes to dgn elements.
However as soon as I assign Resource Font file ( a .rsc file) in the writer advance parameters the workbench crashes, if I remove the resource font file the workbench works fine.
I have attached a screenshot.
FME - 2016.1
Microstation version - V 8.00.04.01
Please suggest.
Regards
Zubair
itay
Forum|alt.badge.img+19
  • Oct 17, 2016 5:46 AM UTC
sounds like a case for support to me.
srg
Forum|alt.badge.img+10
  • Oct 18, 2016 7:20 AM UTC
@zubairsm,
did you check replacing the rsc file with another one instead of removing it to investigate if there is an issue with the rsc file?
zubairsm
  • Oct 18, 2016 7:28 AM UTC
I have already tried with other rsc file but same issue.
Anyway I have raised the issue with safe support team.
Thanks
Zubair
