Microstation DGN v8 igds_type does not set curves
  • Feb 7, 2019 10:49 AM UTC
  • 95 views
I am using FME Desktop 2017.1 and trying to output a Microstation V8 DGN file with curves instead of line strings. I have exposed and set the igds_type attribute to 11 (ie: curve) but the output DGN now has no lines at all. Does anyone have any ideas?
Thanks
Best answer by aquamarine
Hi Dave actually I just worked out the answer myself! I needed to set the igds_type attribute to "igds_curve" rather than "11".
  • Feb 7, 2019 10:52 AM UTC
Maybe a silly question, but have you verified that the FME geometries are indeed arcs and not polylines when arriving at the writer?
  • Feb 7, 2019 10:55 AM UTC
  • Feb 7, 2019 4:04 PM UTC
Hi @david_r I have another issue with the igds_type curve output in Microstation. For some reason, the first two and last two vertices of every curve are not joined together when I output the file to Microstation DGN. Do you know why this would be? They were definitely joined together when I used a normal line_string...
  • Feb 7, 2019 4:35 PM UTC
That's strange. Unfortunately I don't know...
