Method for forcing decimal points between numeric characters in a string?
  • Apr 2, 2025 10:33 AM UTC
  • 148 views
fionasin
Forum|alt.badge.img+13
I have various values in a 'code' field.
A sample would be: A33, B111W, B12, C3V etc, etc.
This issue is, there should be decimal points between all numbers, i.e, these should correctly read: A3.3, B1.1.1W, B1.2, C3V. There does not need to be points between the letters.
I can string replace “33” with “3.3” and continue to do that for all values if I have to, but I’m hoping that there is a more efficient way of capturing these values and using regex or something to force decimal points between the numerical characters. I’m not well adept at using the stringformatter, but maybe there is something there?
Best answer by takashi
Hi ​@fionasin ,
I would use StringReplacer with these parameter settings.
  • Mode : Replace Regular Expression
  • Text To Replace : (\d)(?=\d)
  • Replacement Text : \1.
The regular expression matches any single digit before a digit.
  • Apr 2, 2025 10:56 AM UTC
Hi ​@fionasin ,
fionasin
  • Apr 2, 2025 11:10 AM UTC
Hi ​@fionasin ,
This worked great, thank you!!!
