MDB_ADO reader: An unknown exception occurred
  • Sep 27, 2018 8:38 AM UTC
  • 7 replies
  • 149 views
Hi All,
I am attempting to walk an FME script (using desktop 32 bit) over a large folder of specialised access databases called gINT files (.gpj) and move the data to various CSVs. However it will terminate after several hours with "MDB_ADO reader: An unknown exception occurred", and only write several of the CSVs for the files it has read. It works for smaller sample sets, so I don't believe it is a flaw in the script.
I have a copy of the log, unfortunately it is a bit large to attach. Any help appreciated.
Thanks
-Jack Collins
Best answer by jecollins
It turned out there was something in the reader that was stopping this reading the access files properly, this has now been fixed in the latest FME release. Thank you to the hard working team at Safe for getting that fixed up!
oscard
Forum|alt.badge.img+23
  • Sep 27, 2018 9:45 AM UTC
Does the exception always happen reading the same gINT file? It could be a corrupt file.
  • Sep 27, 2018 10:11 AM UTC
The file can be opened by FME Data Inspector, so I don't believe it is corrupted. But I'll re-run the script and see if it stops on the same file.
steveatsafe
Forum|alt.badge.img+16
I wonder if you are hitting any sort of memory limit with the 32bit process? What's the memory usage look like in the FME log? I'm curious if you have looked at the Windows Task Manager while the job was running to see what sort of memory usage the FME.exe process is up to. You might have success with 64bit FME (installing into a new folder - you don't need to uninstall your existing FME), but you'll also need to have the appropriate drivers for the 64bit version of MDB_ADO.
As an example here's a link to the drivers you may need for FME 64bit: https://www.microsoft.com/en-us/download/details.aspx?id=54920 (32bit and 64bit here at this link)
  • Oct 2, 2018 3:07 AM UTC
It isn't hitting the memory limit, I've checked the FME log and kept an eye on the amount of C drive memory left. I can send the FME log if you want. I normally use 64bit but cannot get it to read the access databases with those drivers.
It is stopping at the same files, and if I run it on just the files it stops on rather than a walk it has the same error come up. I have tried a couple of different walks. I can read it in Data inspector, I have had to install Microsoft Access Runtimes to make them readable in some cases but even after fixing that Workbench won't work.
I have attached the log after running it on just one of the files it is failing on. holebaseuploader.txt
  • Nov 14, 2018 7:01 AM UTC
Hi All,
Thanks for the advise. Safe have had a look at it and it was a bug in the reader. It has been repaired and is going to be fixed in the next release.
Thanks
-Jack
  • Feb 27, 2019 12:15 AM UTC
neilmyoung
Forum|alt.badge.img+3
  • Feb 25, 2025 7:46 PM UTC
​@jecollins - Due to being forced to update to Windows 11, my team are having issues dealing with gINT files. I would love to use FME to export the data. Would you be willing to share your workspace or methodology, as what I worry most about is trying to replicate all the joins that would be required to export useful data and am hoping you may have already worked through a lot of the relationships between the tables to get useful output.
