MBtiles Writer and forcing layers
  • Apr 23, 2025 2:38 PM UTC
  • 135 views
froberts
Forum|alt.badge.img+4
I am having maybe a similar but different issue with the mbtiles writer.  For some reasons the Zoom level dialog is not making a lot of sense to me.  In my case I would like to force the writer to write out levels 0 to 11.
In my head I am thinking I would set minimum zoom level strategy to “Lower”  and then the Minimum Zoom Level to 11.  My assumption is that when we talk about level it matches up with the table below.  However with the above setting I get a mbtiles file with just one level in i (see results 1 below for log).
If I instead set Base zoom to Upper and Minimum Zoom to 0 (run 2 below for log), I get a file with 10 levels.  This is close to what I want, but I want 11 levels.
Any ideas on how to better explain the dialog to me and get me 11 levels??  thanks so much!!!
Run 1 log:
Feature Caching is ON
The workspace may run slower because features are being output and recorded on all output ports regardless of whether or not there is a connection.
    Command line to run this workspace:
        "C:\Program Files\FME\fme.exe" C:\Users\froberts\AppData\Local\Temp\wb-xlate-1745352391322_19716
          --SourceDataset_PNGRASTER "C:\Data\GISData\MovingMaps2025\DRC\2025-04-21Brent\DRC_IFRChart_2024_04_21.png"
          --DestDataset_MBTILES "C:\Data\GISData\MovingMaps2025\DRC\2025-04-21Brent"
          --FME_LAUNCH_VIEWER_APP "YES"
Starting translation...
                FME 2024.2.1.0 (20241202 - Build 24801 - WIN64)
                        FME Form Fixed (node locked-crc)
                       Temporary License: 221 days left.
                      Machine host name is: AM-NAM-L22027
          Operating System: Microsoft Windows 11 64-bit  (Build 26100)
                 Copyright (c) 1994 - 2024, Safe Software Inc.
                               Safe Software Inc.
Current FME version: FME 2024.2.1.0 (20241202 - Build 24801 - WIN64)
System Time: 20250422200634 UTC
FME_HOME is 'C:\Program Files\FME\'
Serial Number: P3G3-TGL9-242Q
OS Locale Name     : en_US
OS Locale Encoding : windows-1252
Process Encoding   : UTF-8
FME API version: '4.0 20240212'
FME Configuration: FME_BASE is 'no'
FME Configuration: FME_MF_DIR is 'C:\Users\froberts\AppData\Local\Temp/'
FME Configuration: FME_MF_NAME is 'wb-xlate-1745352391322_19716'
FME Configuration: FME_PRODUCT_NAME is 'FME(R) 2024.2.1.0'
FME Platform: WIN64
System Status: 370.03 GB of disk space available in the FME temporary folder (C:\Users\froberts\AppData\Local\Temp\wbrun_1745274161825_19716\fmetmp_5)
System Status: 63.68 GB of physical memory available
System Status: 254.72 GB of virtual memory available
START - ProcessID: 30888, peak process memory usage: 46092 kB, current process memory usage: 46092 kB
FME Configuration: Command line arguments are `C:\Program Files\FME\fme.exe' `C:\Users\froberts\AppData\Local\Temp\wb-xlate-1745352391322_19716' `--FME_LAUNCH_VIEWER_APP' `WORKBENCH' `LOG_STANDARDOUT' `YES' `LOG_TIMINGS' `YES' `LogCountServerName' `57088' `LOG_STANDARDOUT' `No' `WORKBENCH_LOG_SERVER' `50853'
FME Configuration: Connection Storage: 'C:\Users\froberts\AppData\Roaming\Safe Software\FME\'
Shared folders for formats are : C:\Program Files\FME\datasources;C:\Users\froberts\OneDrive - Mission Aviation Fellowship\Documents\FME\Formats
Shared folders for transformers are : C:\Users\froberts\AppData\Roaming\Safe Software\FME\Packages\24801-win64\transformers;C:\Program Files\FME\transformers
Shared folders for coordinate systems are : C:\Users\froberts\OneDrive - Mission Aviation Fellowship\Documents\FME\CoordinateSystems
Shared folders for coordinate system exceptions are : C:\Users\froberts\OneDrive - Mission Aviation Fellowship\Documents\FME\CoordinateSystemExceptions
Shared folders for coordinate system grid overrides are : C:\Users\froberts\OneDrive - Mission Aviation Fellowship\Documents\FME\CoordinateSystemGridOverrides
Shared folders for CS-MAP transformation exceptions are : C:\Users\froberts\OneDrive - Mission Aviation Fellowship\Documents\FME\CsmapTransformationExceptions
Shared folders for transformer categories are : C:\Users\froberts\OneDrive - Mission Aviation Fellowship\Documents\FME\TransformerCategories
FME Configuration: No destination coordinate system set
FME Configuration: Current working folder is `C:\Users\froberts\AppData\Local\Temp'
FME Configuration: Temporary folder is `C:\Users\froberts\AppData\Local\Temp\wbrun_1745274161825_19716\fmetmp_5', set from environment variable `FME_TEMP'
FME Configuration: Cache folder is 'C:\Users\froberts\AppData\Local\Temp'
FME Configuration: FME_HOME is `C:\Program Files\FME\'
FME Configuration: Start freeing memory when the process exceeds 191.04 GB
FME Configuration: Stop freeing memory when the process is below 143.28 GB
Creating writer for format:
Creating reader for format:
MULTI_READER(MULTI_READER): Will fail with first member reader failure
Using Multi Reader with keyword `MULTI_READER' to read multiple datasets
Using MultiWriter with keyword `PRIMARY_DEST' to output data (ID_ATTRIBUTE is `multi_writer_id')
Writer output will be ordered by value of multi_writer_id
Loaded module 'LogCount_func' from file 'C:\Program Files\FME\plugins/LogCount_func.dll'
FME API version of module 'LogCount_func' matches current internal version (4.0 20240212)
Emptying factory pipeline
Router and Unexpected Input Remover (RoutingFactory): Tested 0 input feature(s), wrote 0 output feature(s): 0 matched merge filters, 0 were routed to output, 0 could not be routed.
Unwanted Router Input Nuker (TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
PNGRASTER_PNGRASTER_1 Splitter (TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
Restoring 1 feature(s) from FME feature store file `C:\Users\froberts\AppData\Local\Temp\wb-cache--MBSYwz\Main_PNGRASTER -1 2 -1  0  fff5ad21e0cb82f36b31ece57b36748bdab30862.ffs'
Creating reader for format: PNG (Portable Network Graphics)
Trying to find a DYNAMIC plugin for reader named `PNGRASTER'
Loaded module 'PNGRASTER' from file 'C:\Program Files\FME\plugins/gdal/GDAL.dll'
FME API version of module 'gdal/GDAL' matches current internal version (4.0 20240212)
PNGRASTER reader: Opening file 'C:\Data\GISData\MovingMaps2025\DRC\2025-04-21Brent\DRC_IFRChart_2024_04_21.png'
The EPSG number of the FME coordinate system 'LL-WGS84' is '4326'
Successfully read world file 'C:\Data\GISData\MovingMaps2025\DRC\2025-04-21Brent\DRC_IFRChart_2024_04_21.pgw'
FME Configuration: Source coordinate system for reader R_1[PNGRASTER] set to `LL-WGS84' as read from input data
Coordinate System `LL-WGS84' parameters: CS_NAME=`LL-WGS84' DESC_NM=`WGS84 Lat/Longs' DT_NAME=`WGS84' GROUP=`LL' MAP_SCL=`1' PROJ=`LL' QUAD=`1' SCL_RED=`1' UNIT=`DEGREE'
Creating writer for format: MapBox MBTiles
Trying to find a DYNAMIC plugin for writer named `MBTILES'
Writer `MBTILES_1' of type `MBTILES' using group definition keyword `MBTILES_1_DEF'
MBTILES writer: Setting feature type level option 'mbtiles_map_type' to value 'Overlay' for feature type 'Raster1'
MBTILES writer: Setting feature type level option 'mbtiles_tile_format' to value 'PNG' for feature type 'Raster1'
MBTILES writer: Setting feature type level option 'mbtiles_version' to value '1.1' for feature type 'Raster1'
MBTILES writer: Setting feature type level option 'mbtiles_zoom_level_strategy' to value 'Lower' for feature type 'Raster1'
MBTILES writer: Setting feature type level option 'mbtiles_jpeg_compression_level' to value '25' for feature type 'Raster1'
MBTILES writer: Setting feature type level option 'mbtiles_png_zlevel' to value '6' for feature type 'Raster1'
MBTILES writer: Setting feature type level option 'mbtiles_png8_dither' to value 'No' for feature type 'Raster1'
MBTILES writer: Setting feature type level option 'mbtiles_gen_min_zoom' to value '11' for feature type 'Raster1'
MBTILES writer: Setting feature type level option 'mbtiles_pyramid_interpolation_type' to value 'Bilinear' for feature type 'Raster1'
FME Configuration: Using FME Reprojection Engine
Reprojector: Reprojecting from source coordinate system 'LL-WGS84' to destination coordinate system 'WGS84.PseudoMercator'
Reprojector: Recalculating raster cell size from (0.0013524057, 0.0013524058) to (150.54911386992066, 153.95873063891247)
Reprojector: Recalculating raster extents from (10.34355729415, -23.5638441404), (36.309746734149996, 15.3854428996) to (1151439.5309758284, -2700349.9698844347), (4041982.5172783053, 1733661.4725162443)
Caching raster band data: 65.48% complete
Caching raster band data: 100% complete
MBTILES writer: Completed 38.41% of intermediate processing
MBTILES writer: Completed 73.01% of intermediate processing
MBTILES writer: Current zoom level 9 is less than desired minimum zoom level 11. Will not generate additional zoom levels
MBTILES writer: Outputting zoom levels 9 to 9
Destination Feature Type Routing Correlator (RoutingFactory): Tested 1 input feature(s), wrote 1 output feature(s): 0 matched merge filters, 1 were routed to output, 0 could not be routed.
Final Output Nuker (TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
Feature output statistics for `MBTILES' writer using keyword `MBTILES_1':
                               Features Written
DRC_IFRChart_2024_04_21                                                      1
Total Features Written                                                       1
                            Features Read Summary
Total Features Read                                                          0
Run 2 Log:
        "C:\Program Files\FME\fme.exe" C:\Users\froberts\AppData\Local\Temp\wb-xlate-1745352785709_19716
                               Safe Software Inc.
System Time: 20250422201308 UTC
FME Configuration: FME_MF_NAME is 'wb-xlate-1745352785709_19716'
FME Platform: WIN64
System Status: 370.32 GB of disk space available in the FME temporary folder (C:\Users\froberts\AppData\Local\Temp\wbrun_1745274161825_19716\fmetmp_6)
START - ProcessID: 33524, peak process memory usage: 45868 kB, current process memory usage: 45868 kB
FME Configuration: Command line arguments are `C:\Program Files\FME\fme.exe' `C:\Users\froberts\AppData\Local\Temp\wb-xlate-1745352785709_19716' `--FME_LAUNCH_VIEWER_APP' `WORKBENCH' `LOG_STANDARDOUT' `YES' `LOG_TIMINGS' `YES' `LogCountServerName' `57088' `LOG_STANDARDOUT' `No' `WORKBENCH_LOG_SERVER' `50853'
FME Configuration: Temporary folder is `C:\Users\froberts\AppData\Local\Temp\wbrun_1745274161825_19716\fmetmp_6', set from environment variable `FME_TEMP'
MBTILES writer: Setting feature type level option 'mbtiles_zoom_level_strategy' to value 'Upper' for feature type 'Raster1'
MBTILES writer: Setting feature type level option 'mbtiles_gen_min_zoom' to value '0' for feature type 'Raster1'
Caching raster band data: 63.71% complete
MBTILES writer: Completed 23.81% of intermediate processing
MBTILES writer: Completed 47.77% of intermediate processing
MBTILES writer: Completed 70.22% of intermediate processing
MBTILES writer: Completed 93.07% of intermediate processing
MBTILES writer: Cannot generate zoom levels 0 to 10 due to resampling issues between levels 0 and 1. Will generate levels 1 to 10 instead
MBTILES writer: Outputting zoom levels 1 to 10
MBTILES writer: Generating pyramids: Completed 48.99% of intermediate processing
MBTILES writer: Generating pyramids: Completed 93.75% of intermediate processing
                               Features Written
                           Features Written Summary
-~    Feature caches have been recorded at every stage of the translation.     ~-
-~                      To inspect the recorded features,                      ~-
-~              click the feature cache icons next to the ports.               ~-
Translation was SUCCESSFUL with 8 warning(s) (1 feature(s) output)
FME Session Duration: 8 minutes 37.7 seconds. (CPU: 298.3s user, 211.6s system)
END - ProcessID: 33524, peak process memory usage: 10119192 kB, current process memory usage: 142640 kB
FME Session Duration: 3 minutes 13.7 seconds. (CPU: 134.7s user, 56.3s system)
END - ProcessID: 30888, peak process memory usage: 9577948 kB, current process memory usage: 132660 kB
desiree_at_safe
Forum|alt.badge.img+24
Hi ​@froberts!
I’d love to better understand what you're experiencing and what exactly about the Zoom Level dialog is causing confusion. Can you clarify what you mean.
Would you be able to share a sample raster, screenshots, or even a simplified version of your workspace template? That might help clarify things for me and others who want to help.
This isn’t quite in my wheelhouse, but I’m happy to work through it with you to figure out how the zoom level settings behave and how to get the output you're expecting.
Also, for reference, Safe's documentation might shed some light on the parameters in that dialog:
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-ReadersWriters/mbtiles/feature-types-w.htm
Looking forward to digging into this with you! 😊
