Manipulate "Text Location" orientation
  • Aug 6, 2019 9:44 AM UTC
  • 6 replies
  • 280 views
geogaard
Forum|alt.badge.img+15
I am trying to adjust the text orientation by changing the fme_rotation attribute in the TextAdder transformer. However, the text orientation attributes does not take the changes. Do you know how I can access or somehow manipulate the values in the red box from the image below?
In this example i have change the rotation to 116, but the text still have a rotation of 118.
Best answer by ebygomm
If you set autocad_original_rotation to the value you want, it will be written correctly in the DWG file
Forum|alt.badge.img+63
Maybe the TextPropertySetter
So how exactly are you creating this text? Where's that fme_rotation originally coming from?
geogaard
  • Aug 6, 2019 11:43 AM UTC
The text comes from a DWG-file, where the original rotation comes from. I want to manipulate that rotation. Even if I do change the rotation attribute value (fme_rotation or autocad_rotation), it does not change orientation rotation in the text location. Thus when writing back to dwg it uses the original rotation.
Okay, my TextPropertySetter does work if you're sending stuff to the Data Inspector, but not if you write back to a DWG.
The workaround is to first use a CoordinateExtractor to grab the x and y coordinates of the texts, then a Rotator to do the actual rotation, using the x and y coordinate as the rotation origin.
Forum|alt.badge.img+54
  • Aug 6, 2019 1:23 PM UTC
geogaard
  • Aug 6, 2019 1:33 PM UTC
Thank you! that worked like a charm
geogaard
  • Aug 6, 2019 1:34 PM UTC
Yeah, that's what I noticed as well. Thanks for helping!
