LogFile in FME SERVER
  • Jul 16, 2013 10:05 AM UTC
  • 34 views
farfar
Forum|alt.badge.img+12
I look for retrieving LogFileName and copy into my folder. example : When i launch a job, i get a log file in : serverjobsubmitter/FME_74061B13_1373896868934_15164.log. i'd like to move it into another folder like "C:/logs" for each traitment.
Thanks an advance.
farfar
  • Jul 16, 2013 11:31 AM UTC
have you looked at the FMEServerLogFileRetriever?
David
farfar
  • Jul 17, 2013 8:40 AM UTC
I use FMEServerLogRetriever and get attribute _log_attr.
are there some example to create a logfile and copy this attribute to it with PythonCaller or other transformer?
I'm a new fme user.
Thanks an advanc.
Farfar
fmelizard
Forum|alt.badge.img+22
  • Jul 18, 2013 8:26 AM UTC
Hi Farfar
Once you have the log file in your attribute _log_attr you can just use the Text File writer to write that log file anywhere you want.  Connect the _log_att  (which contains the actual log file) to the the text_line_date attribute on the destination. Screen shot here:
http://screencast.com/t/QIm5Bl3oX
