Log file for unsaved workspace
  • Sep 14, 2018 4:34 PM UTC
  • 89 views
Yesterday I started a Workspace which is taking a lot of time to process. About 24 hours up to now. I didn't save the workspace. I'd like to inspect the log file to see if I could find a potential problem and also see the time spent on each operation. Is the log file saved somewhere. Thanks,
Simon
Best answer by hollyatsafe
Hi @simon_fb,
In the translation log of your workspace at the very top it states a Command-line to run this workspace and should provide details of a Temporary folder. By default logs are saved in the same location as the workspace however it doesn't like a log file is created for unsaved workspaces.
However even whilst a workspace is running you should be able to Right Click on the translation log and select 'Save Log Text'
  • Sep 14, 2018 4:40 PM UTC
I forgot to mention I have FME2016.1
  • Sep 14, 2018 5:18 PM UTC
Hi @simon_fb,
