LAS Writer: Failed to obtain point cloud data from feature
  • Oct 25, 2024 6:57 PM UTC
  • 114 views
rhonda.edwards
LAS writer: Failed to obtain point cloud from feature.  Only features with point cloud geometry are expected
LAS writer: An error has occurred. Check the logfile above for details
Help. I’m receiving the two lines of error shown above ^
I am trying to modify a folder of .LAS data to create a TIN based on a certain classification (Ground).
I don’t understand why I’m receiving these error codes if all of the other items are running and previewing successfully.
FORM Workspace: Read in .LAS, Write out .LAS
todd_davis
Forum|alt.badge.img+23
  • Oct 27, 2024 9:11 PM UTC
The generated Tins can’t be written to Las file. From the tingenerator onwards, you have moved away from a format storable as a LAS file.
Cheers,
Todd
rhonda.edwards
Hi Todd,
Yep! Found that out today - the TIN generated vector data has lost the point cloud geometry.
As an update, the workflow has since been modified to include a DGNStyler transformer and a TIN writer to use as a level in MicroStation CONNECT.
Thanks.
