KML writer: How to draw wireframe of solids in different color (better display)
  • February 20, 2018
  • 19 views
mhab
Forum|alt.badge.img+10
Hello
I write solids to KML and want to give the borderlines/wireframe of the solid a different color/alpha in order to get better visibility of the solid.
I try KMLStyler with Color 0,0,0 (black) and Opacity 1 and Fill Color set to red and Fill Opacity set to 0.7.
I don't see any effect however. There is no wireframe visible, like I used to get it years ago with the first version of KML writer ...
Any hints what maybe wrong ?
Seems like I need to duplicate the wireframe as independent feature ...
arnold_bijlsma
Forum|alt.badge.img+14
When you say 'solids', do you mean 'polygons'? (I work in the wastewater industry, and 'solids' have a bit of a different meaning here ;-))
I just had a quick try and am able to create a red transparent polygon with a thick black border without problem (see image). And be aware of the setting near the top "Allow Unique Styles Per Feature"
(I am using v2017.0.0)
mhab
  • February 20, 2018
Sorry, I mean solids. I have no problem with polygons/areas.
Solid in the sense of FME a 3D volume feature.
In my current case an extruded polygon.
arnold_bijlsma
Even going from 2D to 3D still works fine for me:
