KML Styler Custom Icon
  • May 16, 2017 5:31 PM UTC
  • 318 views
I'm trying to add a custom icon using the KMLStyler. The icon is saved on google drive. I used Attribute Manager to add a new attrubute called "Symbol_Icon" thats value is the google drive url link, then I used the KMLStyler to set the icon name to the newly created attribute. I'm getting the "red x" once I open the kml in google earth. Screenshots below, any suggestions?
Best answer by itay
Hi @mikeymess,
It could be a limitation of the KMLStyler that URL's of a internet drive are not yet supported.
If you download one icon and reference it from a local drive, does that work?
itay
Forum|alt.badge.img+19
  • May 16, 2017 5:43 PM UTC
Hi @mikeymess,
  • May 16, 2017 5:52 PM UTC
Hi @mikeymess,
@itay Thank you for the quick reply. Yes, it does work when I link to a local drive. I will be sharing this file with another organization and need the icon to be accessable to my end users as well. I assume if I save the file to kmz the symbol with carry over, correct? Is there anyway to share an icon with a kml rather than kmz?
Forum|alt.badge.img+63
I had a similar issue with a customer recently. I don't think we found a resolution at that time.
Thinking out loud, you can write to a KMZ and include the icon files, then refer to them with a local path. I used that technique for images referred to in infowindows, but perhaps it'd work with icon files too. I;ll have to dig up a workspace that does that.
itay
  • May 16, 2017 6:00 PM UTC
I think you are better off by providing them a kmz:
https://www.gearthblog.com/blog/archives/2016/03/custom-icons-google-earth.html
