Keeping raster attributes when writing out rasters
  • Sep 12, 2017 10:44 AM UTC
  • 9 replies
  • 182 views
I have an FME2017 desktop workbench where I am writing out to rasters. I don't mind which raster format I write out to (eg. GeoTiff, Esri Ascii Grid,) as long as the raster is readable in ESRI ArcGIS software. I am currently writing out to GeoTiff successfully and the three bands (R, G, B) are displaying correctly in ArcGIS.
The raster only has 10 distinct combination of bands and I would like to create a new band that is based on the combination of the RGB bands and give each cell in the raster a value for this new band.
I would then like to output this new band with the Raster and make the raster displayable by this band in ArcGIS.
Does anyone know how to do this?
Thank you in advance
Best answer by jdh
In that case you want to use a RasterPaletteGenerator which will convert selected bands to a new band with a palette.
jdh
Forum|alt.badge.img+41
  • Sep 12, 2017 2:24 PM UTC
You can use a RasterExpressionEvaluator to create additional band(s) based on the values of other bands.
Additional bands can be displayed in arcmap by changing the setting of the layer symbology to stretched and selecting the appropriate band.
My personal preference is for GeoTiffs when working with ArcMap, though be advise that there is a 2GB limit.
  • Sep 12, 2017 3:14 PM UTC
Thank you for your response @jdh. But I don't I think I explained myself properly.
The 10 distinct combinations of the 4 RGBA bands are colours and the new band that I want is just a number that represents each of these colours. Therefore I don't think I can use the RasterExpressionEvaluator for this, as far as I am aware. I thought perhaps the answer lies in palettes. So I tried to define a palette using the AttributeCreator by adding the following text into the text editor:
RGBA32 0 0,0,0,0 1 0,0,254,255 2 50,101,254,255 3 127,127,0,255 4 254,203,0,255 5 254,152,0,255 6 254,0,0,255 7 254,0,254,255 8 229,254,254,255
I followed this with the RasterPaletteAdder:
However I keep getting this error:
@RasterPaletteAttributes: A selected band has intepretation 'RED8', which is not a valid interpretation for a band with palettes. Please ensure that only bands with an interpretation of UINT8, UINT16, or UINT32 are selected. @SelectRaster may be used to modify selection
I feel like I'm on the right track but am missing something...
courtney_m
Forum|alt.badge.img+23
  • Sep 12, 2017 3:53 PM UTC
Hi, @aquamarine. Have you tried using the RasterInterpretationCoercer before your RasterPaletteAdder? You can force the interpretation to UINT8.
  • Sep 12, 2017 4:04 PM UTC
Thanks @courtney_m
Adding the RasterInterpretationCoercer and forcing it to UINT8 solved the problem! Are you able to explain why I needed to do this? I am not very familiar with raster interpretations and bands and palettes so am a bit perplexed with all this.
Regards
jdh
  • Sep 12, 2017 4:05 PM UTC
courtney_m
  • Sep 12, 2017 4:10 PM UTC
Thanks @courtney_m
Regards
Only rasters with an interpretation of UInt8, UInt16, or UInt32 can contain a palette. So in order to add a palette to your raster, you have to first do a transformation on the raster to force it to have an appropriate interpretation.
  • Sep 12, 2017 4:58 PM UTC
Thansk @jdh
this method also works for me. It is probably better for me to use the RasterPaletteGenerator than the RasterPaletteAdder in this case, because I am exporting to GeoTiffs and GeoTiffs can only have 1 band.
  • Sep 13, 2017 3:26 AM UTC
Hi @aquamarine, as @jdh suggested, you can use the RasterPaletteGenerator to transform an RGB24 or RGBA32 raster into a UInt8, UInt16, or UInt32 single band raster with a palette. However, you cannot specify which destination cell value should be mapped to a specific (R,G,B) or (R,G,B,A) combination. In other words, the order of the palette entries cannot be controlled.
If you need to specify the destination single cell value corresponding to a specific (R,G,B) or (R,G,B,A) combination, the RasterExpressionEvaluator would still be a solution.
For example, assuming the mapping rule between each destination cell value and original (R,G,B) combination has been given as:
0  0,0,0
1  0,0,254
2  50,101,254
3  127,127,0
4  254,203,0
5  254,152,0
6  254,0,0
7  254,0,254
8  229,254,254
These two RasterExpressionEvaluators transform an RGB24 raster into a UInt8 single band raster. See also the attached demo: rgb-raster-to-single-band-raster-demo.fmw (FME 2017.0)
  • Sep 13, 2017 8:27 AM UTC
0  0,0,0
1  0,0,254
2  50,101,254
3  127,127,0
4  254,203,0
5  254,152,0
6  254,0,0
7  254,0,254
8  229,254,254
Thank you @takashi .  I don't need to change the order of the palette entries in this case, but in future this information on how to use the RasterExpressionEvaluator could come in very handy.  Thanks!!
