JSON Writer Line Endings Are Wrong
  • Mar 8, 2016 9:06 PM UTC
  • 33 views
Using a JSONFormatter (pretty) and JSON Writer in series, the output file contains literally the characters \\r\\n with no actual line returns. Snippet of the output:
"_formatted":"{\\r\\n \\"request\\" : [\\r\\n {\\r\\n \\"addDate\\" : \\"/Date(1449794160000-0600)/\\",......
Connecting an Inspector to the to the formatter works as expected.
I should mention that I am using the 2016.1 Beta version (for the Elasticsearch goodness it contains.)
Best answer by takashi
Hi @t1, looks like you have written the entire json document as a string value of a json object member. If you need to write the formatted json document as a json document, you can use the Text File writer, rather than the JSON writer.
  • Mar 9, 2016 8:53 AM UTC
  • Mar 9, 2016 3:18 PM UTC
Makes perfect sense now... JSON writer saves attributes as JSON. I just needed to dump my JSON doc to a text file.
