JSON Transformer: Headlines /Error on Reading
  • Jan 12, 2017 4:06 PM UTC
  • 69 views
Hi Guys,
I am new at the FME Software and actually trying to transform an json file to an csv file. With the example i could create such flow that works.
I checked the Output and wondering a little bit that the headlines of the json objects are in the fields. Example:
{"cruise_nid":413358
Cruise_nid is the object name (in a json array) and the 413358 is value. In my powershell script that i actually using for that transformation, the cruise_nid used as Headline. How i can configure the JsonFragmenter to use the objective names as Headlines?
The second Point that i got is that on anorther json i got an error that the json is not valid:
A JSON syntax error was found at line 39, column 28
A sequence of bytes was found which is invalid in the utf-8 Encoding.
I checked the json file, but there isnt a column 28 in the line 39. In column 59 i got an umlaut. But i thought that that will be in UTF8 be no Problem. Any tips?
Regards
Timo
  • Jan 13, 2017 4:10 PM UTC
Hi there,
Any hints?
Regards
Timo
jdh
Forum|alt.badge.img+41
  • Jan 13, 2017 8:32 PM UTC
Hi there,
Any hints?
Regards
Timo
It would probably be helpful to post the actual json snippet and/or the workspace that is producing the error.
