JSON into Postgres
  • Mar 2, 2016 8:23 AM UTC
  • 8 replies
  • 148 views
Hi All,
I'm trying to import JSON into a postgres table which has a JSON column, Unfortunately I get an error of:
PostgreSQL connection: Column 'data' has unknown type with OID 114, treating as char(80)
Is there a way to increase the default past 80 characters? As the reason its failing to insert to postgres is the JSON isn't valid cause it gets truncated to 80 characters.
The table within sql has data type of JSON, its FME that doesn't recognise this and then imposes a char(80) on it. So I can't change the length in postgres as there is no length to JSON to set.
  • Mar 2, 2016 11:06 AM UTC
Which version of FME desktop?
FME desktop 2015.0 WIN32
  • Mar 2, 2016 11:27 AM UTC
I have tried with FME 2016 and it works with a simple example. Then tried with FME 2015.1 and I see the same error.
I used the new AttributeValidator to validate the JSON before writing to the table.
I've just upgraded my version of FME to 2015.1 and it seems to now work for me. very odd it now doesnt work for you.
  • Mar 2, 2016 11:43 AM UTC
What specific build I'm guessing 15485?
I'm using an older 15480. Must update!
yep you are right my build is 15485
  • Mar 2, 2016 12:06 PM UTC
Just updated to 15485 and also works for me.
Glad you got there in the end.
