JSON – Get Attribute values from file
  • Nov 14, 2017 8:03 AM UTC
  • 5 replies
  • 85 views
I have a JSON file and need to extract the attributes from this file.
How can I do it?
Example:
"id" : null,
"revisionNumber" : "1.0.0",
"periodTimeInterval" : {
"start" : "2014-10-10T01:00Z",
"end" : "2014-10-11T01:00Z"
"timeSeries" : [
"id" : "silo:67688:536653:raw",
"name" : null,
"tskeys" : null,
"dimensions" : {
"attribute" : [
"value" : {
"item" : [],
"type" : "String",
"value" : null
"name" : "Datenquelle"
"value" : {
"item" : [],
"type" : "Integer",
"value" : "0"
"name" : "Netzbetriebsplanung"
"value" : {
"item" : [
"key" : "0",
"name" : "from",
"type" : "DatumZeit",
"value" : "1990-01-01T00:00:00.000"
"key" : "0",
"name" : "factor",
"type" : "Float",
"value" : "1"
"key" : "0",
"name" : "constant",
"type" : "String",
"value" : "0"
"type" : "Zeitwerte",
"value" : null
"name" : "Bilanzfaktor"
"value" : {
"item" : [],
"type" : "NotizRtf",
"value" : null
"name" : "Notiz"
"value" : {
"item" : [],
"type" : "NotizUnformatiert",
"value" : null
"name" : "Zeitreihenqualit_t"
"measures" : {
"attribute" : [
"value" : {
"item" : [],
"type" : "int",
"value" : "67688"
"name" : "abfrageid"
"value" : {
"item" : [],
"type" : "int",
"value" : "536653"
"name" : "zeitreiheid"
"value" : {
"item" : [],
"type" : "string",
"value" : "RAW"
"name" : "datenquelle"
"value" : {
"item" : [],
"type" : "string",
"value" : "OHNE"
"name" : "datenausgerollt"
"name" : null
"period" : [
"timeInterval" : {
"resolution" : "PT60M",
"point" : [
"datumZeitUTC" : 1507597200000,
"position" : 1,
"quantity" : 45.48
"datumZeitUTC" : 1507600800000,
"position" : 2,
"quantity" : 43.69
"datumZeitUTC" : 1507604400000,
"position" : 3,
"quantity" : 42.41
Thank you very mutch for any suggestions.
Zoran
jneujens
  • Nov 14, 2017 8:24 AM UTC
There is a wrong syntax in your json example.
  • Nov 14, 2017 8:37 AM UTC
Hi @zoran68, generally you can use JSON reader or JSON*** transformers to parse a JSON document. The way depends on what fearture(s) you need to extract from the document.
Note: As @jneujens mentioned, your document is not a valid JSON. Please post a valid JSON document if you expect a more specific answer.
  • Nov 14, 2017 8:45 AM UTC
testdaten-forum.jsonHi takashi, I think this is the copy paste Problem.
I attached the sample file and hope at the help.
  • Nov 14, 2017 8:54 AM UTC
I attached the sample data and hope you can help me.
Thanks
Zoran
  • Nov 14, 2017 10:31 AM UTC
Thanks
Zoran
The document still contains wrong syntax. Any software cannot parse it unfortunately.
