Joining GDB with GML and writing to GML -> missing geometry in output gml
  • Mar 25, 2020 9:00 AM UTC
  • 5 replies
  • 90 views
jonathanklarup
When joining file-GDB dataset with GML dataset and then writing to GML the geometry is missing in the output, if I dont join with the GDB the geometry is in the output.
Is there some hidden GDB features which causes this ?
Or what is happening ?
Forum|alt.badge.img+54
  • Mar 25, 2020 9:11 AM UTC
How are you joining the data?
jonathanklarup
This is embarrassing my fault. Featurejoiner was set to use the geometry from the gdb.
jonathanklarup
  • Mar 25, 2020 9:32 AM UTC
Happily, these sorts of errors are the easiest ones to fix :-)
jonathanklarup
They sure are! Thank you for helping putting me in the right direction :)
