Issue with Real64 or Real32 reformatting when writing to file a geodatabase.
  • Mar 17, 2020 11:00 PM UTC
  • 108 views
I'm reading an HTML table from a website and its bringing in both Real64 and Real32 numbers which I'm writing to a Geodatabase table. No matter if I specify column types of Float, Double, or Integer I get unwanted results where the number has a comma separator in the thousandth position (From table) - the resulting number adds a period in the output. Some of the numbers are dropping a zero when the number ends with zero: 8450 becomes 845. Has anyone experienced this before?
  • Mar 17, 2020 11:49 PM UTC
Hi @gary, how about removing commas from the number? You can use the StringReplacer to remove all commas from a string with this setting.
  • Mode: Replace Text
  • Text to Replace: ,
  • Replacement Text: <not set>
  • Mar 18, 2020 4:14 PM UTC
@takashi Thank you, that did the trick. I had looked at the StringReplacer before but for some reason had got different results.
