Issue publishing Apache Kafka package to FME Server
  • Sep 25, 2019 7:03 PM UTC
  • 7 replies
  • 127 views
We're getting a generic "Package access failed" message in the log when we try to publish a workspace with the Apache Kafka package. Any assistance would be much appreciated.
Best answer by nathanatsafe
@richsnyder0 Would you please double check that the FME Server user uploading the package has the Packages > Upload permission? Please retry once confirmed and if that doesn't do the trick, we may need to take a look at the Tomcat access logs.
Thanks,
Nathan
nathanatsafe
Forum|alt.badge.img+9
Hi @richsnyder0,
I haven't seen that error before but I think the first place to start would be to double check that your FME Server is build 19231 or higher - as I believe that's the minimum required build for version 1.0.2 of the Apache Package. Could you confirm this?
Best,
Nathan
Hi @nathanatsafe - you can see in line 2 of the screenshot that we're using build 19630.
nathanatsafe
Right - my mistake. I'll check with the Packages team.
nathanatsafe
Thanks,
Nathan
nathanatsafe
  • Sep 25, 2019 7:43 PM UTC
Thanks,
Nathan
Thanks,
Nathan
@nathanatsafe that's it - didn't see it before. thanks for the quick turnaround!
nathanatsafe
No problem! Glad it was a quick solution.
