Issue authorizing FMEServer for ArcGIS Online
  • Jan 9, 2019 3:06 PM UTC
  • 47 views
spatialphil
Hi @Mark2AtSafe, @RylanAtSafe
Having trouble authorizing FME Server (FME Server 2017.0 - Build 17259 - win64) for use with ArcGIS Online. The FMEServer instance is part of a private network, therefore I have followed examples including those at:
  1. https://knowledge.safe.com/questions/43567/arcgis-online-oauth-authorize-issue-on-fme-server.html
  2. https://knowledge.safe.com/questions/65076/connecting-to-arcgis-online-via-fme-server.html
  3. https://knowledge.safe.com/articles/40215/configuring-fme-server-to-use-oauth-based-web-conn.html
I have done the following:
  • The FMEServer has been enabled for HTTPS
  • The service account under which FMEServer runs on the server has necessary proxy whitelisting to hit the AGOL domains
  • Since the FMEServer is private, it is not accessible publicly, nor has a public DNS entry. So as per the example in (3) I have set up a nip.io redirect to the IP address of the 'private' FMEServer
  • I've got a registered application in AGOL (so got a clientId, clientSecret etc).
  • The redirect URL has been set up in both AGOL and on the FME Server.
FME Server ESRI ArcGIS Online Config:
ArcGIS Online Redirect Config:
But when I go to authorize in FME Server it still returns.... :(
Any more ideas????
Much appreciated
Phil
philippeb
Forum|alt.badge.img+23
  • Jan 10, 2019 9:31 PM UTC
Are you creating your AGOL connection with Web Connections in FME Server?
I suggest you read this : https://knowledge.safe.com/questions/57120/error-reading-arcgis-online-agol-feature-layer.html
