Isolate text from .csv column
  • Aug 19, 2013 10:28 PM UTC
  • 52 views
Was wondering if anybody has split text from a .csv column into to seperate columns?
I have a column named "Coordinates" with x,y data with the word POINTZ before the coordinate.
Example: POINT Z (-113.807295690 52.269077310 842.30)
I would like to put just the values in seperate columns (X & Y) containing no text.....
Once I have the x,y in seperate columns i'm assuming its easy to convert the .csv to a .shp
Any thoughts
  • Aug 20, 2013 3:47 AM UTC
There are several ways, I would use a StringSearcher with these settings:
Attribute: Coordinates
Regular Expression: ^.*\\(([^\\s]+)\\s+([^\\s]+)\\s+([^\\s]+)\\)$
Matched Parts Attribute: _coord
The StringSearcher adds a list attribute (coord{}) to each feature.
If "Coordinates" is "POINT Z (-113.807295690 52.269077310 842.30), for example, the list elements will be:
_coord{0} = -113.807295690
_coord{1} = 52.269077310
_coord{2} = 842.30
Takashi
  • Aug 20, 2013 8:04 AM UTC
the text looks to be in the WKT format. If so, you could use a GeometryReplacer (with "OGC Well Known Text" as format) to convert the text into a geometry. Then use a CoordinateExtractor to get the individual values.
David
  • Aug 28, 2013 5:30 PM UTC
Takashi, I don't seem to be able to get this option to run even though it appears straight forward?
I do not see the list Attributes that the StringSearcher is supposed to create?  _coord{0}
I'm a little lost when going from the StringSearcher to the GeoMedia SQL Server Warehouse.
  • Sep 9, 2013 8:09 PM UTC
Hi Takashi, is their any other way to perform this task, i'm not familiar with this type of coding...
Also not sure how to implement this code into the the StringSearcher parameters?
--Do I use Constant
--Do I use multiple StringSearcher Transformers?
--Where do you set the _coord{0} . . . ?
Tyler
