Is there any way to convert light-weight Polylines to 3D Polylines?
  • Jun 15, 2018 1:37 PM UTC
  • 204 views
Hello, I have a 2D City Map .*dxf file. I draped my city map on digital terrain model to obtain a 3D city map. It works fine but when I try to use .*dxf/.*dwg writer, ? see this problem.
"AutoCAD Writer: Encountered a feature with inconsistent Z values, and type 'autocad_lwpolyline'. For this type, only geometry with constant Z values, or 2D geometry are supported. Dropping Z values"
In my output, the geometry which consist of 'autocad_lwpolyline' does not have Z values. Is there any way to solve this problem?
Best answer by takashi
Possibly the features have the format attribute "autocad_original_entity_type" with the value "autocad_lwpolyline". Try removing it before writing.
  • Jun 15, 2018 1:38 PM UTC
@MarkAtSafe
lars_de_vries
Forum|alt.badge.img+10
You could try to set the attribute autocad_entity to autocad_polyline or autocad_3dpolyline.
  • Jun 15, 2018 2:16 PM UTC
  • Jun 15, 2018 6:42 PM UTC
Hello, I changed the format attribute autocad_original_entity_type values to autocad_3dpolyline and it works fine. Thank you both for your help.
