Is there a way to use FME to pull the stats for ArcGIS server and create a table or publish to a dashboard?
  • March 2, 2020
  • 43 views
Is there a way to use FME to pull the stats for ArcGIS server and create a table or publish to a dashboard? I would like to pull these out and publish so management can see usage.
nielsgerrits
Forum|alt.badge.img+54
I think you mean Statistic Reports?
Yes you can, using the REST API, querying it with HTTPCallers. See the ESRI documentation.
Multiple ways to create dashboards. Default functionality (HTMLReportGenerator / ChartGenerator) or custom using RCaller.
