Is there a way to offset a read to an Esri Feature Server location?
  • Jan 15, 2024 12:54 PM UTC
  • 19 views
willhwilson
Forum|alt.badge.img+8
I am highlighting the sql logic i would use in database environment that i am looking to replicate here. It does not accept that logic.
joepk
Forum|alt.badge.img+22
  • Jan 16, 2024 9:19 AM UTC
Max Features to Read works like your LIMIT logic.
As a workaround you could Max read your LIMIT + OFFSET (so 75000 features) and then use a Sampler to take the last 25000 features?
imageBut there is probably some SQL database wizardry possible to avoid having to read those first 50000 features.
