Is it possible to write Geodatabase metadata using FME Cloud/Server?
  • Jan 7, 2019 10:34 AM UTC
  • 5 replies
  • 86 views
l_d
Only the Open API Geodatabase writer can be used on FME Server/Cloud, which doesn't allow you to expose the 'geodb_type' and 'geodb_metadata_string' format attributes.
Is anyone aware of a workaround for writing metadata to Geodatabase? This seems to be a major drawback of Server/Cloud if not.
itsmatt
Forum|alt.badge.img+48
  • Jan 7, 2019 3:45 PM UTC
Sorry, @Id but I think you're out of luck there.
Perhaps @trentatsafe might know of a trick?
Forum|alt.badge.img+63
I haven't tried this myself, but if you run FME Server and have the ESRI libraries installed it should work, right? See this thread for more info.
itsmatt
  • Jan 8, 2019 9:12 AM UTC
Problem here is that FME Cloud runs on a Linux server which doesn't support the ESRI formats. While you can install ArcGIS Server on Linux I still don't think that the FME Readers and Writers for the ArcObjects formats will work.
But FME Server on Windows should be able to do it, right?
itsmatt
  • Jan 8, 2019 9:25 AM UTC
Yeah for sure!
